fwiw, I’ve found sth in the posts:
- it seems Aisler is using a 1.8mm mill bit for all designs, including “complex” rated ones (which mine is, because it has 4 layers)
so my minor issue with the small space in the “SW1” board corner: this should be fixed to use a 1.8mm arc?
- rgd my SMA connector issue … apparently, @holzi has created a footprint for the exact part I am using=) coincidence.
awesome!! I will dig into that. not sure if the Aisler mill dia change breaks that or if it still works though.
but even if so, my audio jack problem remains … the part vendor’s (CUI) footprint doesn’t work … I think … not sure, as said, I’m a newbie;)
