2 Layer 1.6mm 70µm ENIG Design Rules
Last Updated: 04/12/2025
Minimum Copper Features
Description Capability
min. tracewidth 175 µm / 7 mil
min. SMD pad size 200 µm / 8 mil
min. spacing copper / copper 175 µm / 7 mil
min. spacing NPTH / copper 250 μm / 10 mil
min. spacing NPTH slot <1.8 mm / copper 300 μm / 12 mil
min. spacing NPTH slot >= 1.8 mm / copper 300 μm / 12 mil
min. copper to edge clearance 300 μm / 12 mil
Surface Finish
We use Electroless Nickel Immersion Gold (ENIG) this surface finish offers good surface planarity and high oxidation resistance.
surface finish ENIG
Nickel thickness
Gold thickness
4.0 µm -7.0 µm
0.05 µm -0.1 µm
PCB Dimension
min. dimension >10 mm / >0.4 in
max. size 500 x 500 mm / 19.68 in x 19.68
Plated Through Hole (PTH)
All drills with a diameter larger than 0.45 mm are categorized as plated through hole for component mounting, we will enlarge the drill diameter to compensate for the copper plating thickness to ensure that components can be mounted more easily.
min. PTH drill size 0.5 mm / 0.02 in
max. PTH drill size 5.6 mm / 0.22 in
min. PTH annular ring 300 μm / 12 mil
Vias
All drills with a diameter up to 0.45 mm are categorized as via drill and will not be subjected to any adjustments by us.
min. via drill 0.25 mm / 10 mil
max. via drill 0.45 mm / 20 mil
min. via annular ring 175 μm / 7 mil
Minimum Drill Spacing
min. drill spacing 300 μm / 12 mil
NPTH Slots
NPTHs Slots that are smaller than 1.8 mm are nibbled. This is a time-intensive process, so we reserve the right to limit the use of nibble slots in a design. Diameters above 1.8 mm will be milled and are thus preferred.
preferred NPTH slot diameter >= 1.8 mm / 0.07 in
min. NPTH slot diameter 0.8 mm / 0.032 in
max. NPTH slot diameter :infinity: No restriction
PTH Slots
min. PTH slot diameter 0.7 mm / 0.028 in
max. PTH slot diameter 2.6 mm / 0.11 in
min. PTH slot annular ring 300 µm / 12 mil
Silkscreen
The smallest supported width is 150 µm / 6 mil, all silkscreen features with a width less of that will be adjusted. Silkscreen printed on pads is not supported, we use openings in the soldermask as reference to cut away / remove the silkscreen in the affected area. Do not use the silkscreen to produce large fillings, designs which cover more than 25% per PCB side will be rejected.
min. silkscreen text height 800µm / 32 mil
min. spacing silkscreen / pad 125 µm / 5 mil
silkscreen on pad not supported
max. Silkscreen 25% of Board size
Soldermask
soldermask dam between pads recommended but not required
min. soldermask dam 100µm / 4 mil
suggested soldermask expansion 50 µm / 2 mil
Castellated Edges
Castellated edges are manufactured free of charge, please refer to our documentation on how you can set them up.
Additional Notes
  • Buried, blind, micro or tented vias are not supported.
  • User-defined subpanels are not allowed, see also here.
  • Pressfit components are currently not supported.
