PCB Design Rules
Board surface finishes
We offer 2 Layer PCBs with an option of HASL and ENIG as surface finish, if you use small drills, castellated edges or small trace width/spacing it is required to choose ENIG as surface finish.
Feature HASL allowed ENIG required
min. drill diameter ≥ 0.3 mm ≥ 0.25 mm
contains castellated holes :heavy_multiplication_x: :heavy_check_mark:
min. trace width/spacing (Cu 35 µm) 200 µm/150 µm 125 µm/125 µm (100 µm /100 µm for 6L+)
min. trace width/spacing (Cu 70 µm) 225 µm/225 µm 175 µm/175 µm
Design Rules
We have different rules depending on the technologies used.
35 µm
70 µm
