General specifications
The following specifications and options apply to all printed circuit boards:
| Service Level | Blitz / Budget |
| Origin | Germany / Europe |
| RoHS/Reach compliant | |
| Solder Mask Color Options | |
| Silkscreen Color Options |
Available products
Below you will find our printed circuit board products available for ordering through our user interface. Please ensure that you take the relevant design rules into account for the desired configuration.
2 Layers
| Product | 2 Layer 1.6 mm 35 µm HASL | 2 Layer 1.6 mm 35 µm ENIG |
| Design Rules | open | open |
| Stackup | variable | variable |
| Layers | 2 | 2 |
| Surface finish | HASL | ENIG |
| Base material | FR4 TG 140°C | FR4 TG 140°C |
| PCB Thickness | 1.6 mm (63mil) | 1.6 mm (63mil) |
| Copper thickness | 35µm | 35µm |
| Product | 2 Layer 1.6 mm 70 µm HASL | 2 Layer 1.6 mm 70 µm ENIG |
| Layers | 2 | 2 |
| Copper thickness | 70µm | 70µm |
4 Layers
| Product | 4 Layer 1.6 mm 35 µm ENIG | 4 Layer 0.8 mm 35 µm ENIG |
| Stackup | open | open |
| Layers | 4 | 4 |
| Surface finish | ENIG | ENIG |
| Base material | FR4 TG 150°C | FR4 TG 150°C. |
| PCB Thickness | 1.6mm (63 mil) | 0.8 mm (32 mil) |
| Copper thickness | 35µm on all Layers | 35µm on all Layers |
| Product | 4 Layer 1.6 mm 70 µm | 4 Layer 0.8 mm 70 µm |
| Design Rules | ENIG: open, HASL: open | open |
| Stackup | Details | Details |
| Layers | 4 | 4 |
| Surface finish | HASL/ENIG | ENIG |
| Base material | FR4 | FR4 |
| Copper thickness | 70µm outer / 35µm inner layers | 70µm outer / 35µm inner layers |
6+ Layers
| Product | 6 Layer 1.6 mm 35 µm ENIG | 8 Layer 1.6 mm 35 µm ENIG |
| Layers | 6 | 8 |
| PCB Thickness | 1.6mm (63 mil) | 1.6 mm (63 mil) |
Don’t find what you are looking for?
For our Amazing Assembly services we offer other technologies (e.g. different stackups, mechanical processing). The only limitation is that your project needs to be prototypable with one of our prototyping technologies above. If you have further questions, feel free to contact us here
