2 Layer 1.6mm 70µm HASL
Last Updated: 04/12/2025
Minimum Copper Features
| min. spacing copper / copper | 225 µm / 9 mil | |||
| min. spacing NPTH / copper | 250 μm / 10 mil | |||
| min. spacing NPTH slot <1.8 mm / copper | 300 μm / 12 mil | |||
| min. spacing NPTH slot >= 1.8 mm / copper | 300 μm / 12 mil | |||
| min. copper to edge clearance | 300 μm / 12 mil |
Surface Finish
We use lead-free Hot Air Surface Leveling (HASL) for this product portfolio, this surface finish is low cost and suitable for many applications.
PCB Dimension
Plated Through Hole (PTH)
All drills with a diameter larger than 0.45 mm are categorized as plated through hole for component mounting, we will enlarge the drill diameter to compensate for the copper plating thickness to ensure that components can be mounted more easily.
Vias
For economic manufacturing of simpler boards, we may increase the drill size up to a diameter of 0.45 mm. An annular ring of 175 µm is required, and the absolute minimum to compensate for the larger drill. Wherever possible, a minimal annular ring of 200 µm must be used.
Minimum Drill Spacing
NPTH Slots
NPTHs Slots that are smaller than 1.8 mm are nibbled. This is a time-intensive process, so we reserve the right to limit the use of nibble slots in a design. Diameters above 1.8 mm will be milled and are thus preferred.
| preferred NPTH slot diameter | >= 1.8 mm / 0.07 in | |||
| min. NPTH slot diameter | 0.8 mm / 0.032 in | |||
| max. NPTH slot diameter |
PTH Slots
| min. PTH slot diameter | 0.7 mm / 0.028 in | |||
| max. PTH slot diameter | 2.6 mm / 0.11 in | |||
| min. PTH slot annular ring | 300 µm / 12 mil |
Silkscreen
The smallest supported width is 150 µm / 6 mil, all silkscreen features with a width less of that will be adjusted. Silkscreen printed on pads is not supported, we use openings in the soldermask as reference to cut away / remove the silkscreen in the affected area. Do not use the silkscreen to produce large fillings, designs which cover more than 25% per PCB side will be rejected.
| min. silkscreen text height | 800µm / 32 mil | |||
| min. spacing silkscreen / pad | 125 µm / 5 mil | |||
| silkscreen on pad | not supported | |||
| max. Silkscreen | 25% of Board size |
Soldermask
| soldermask dam between pads | required for HASL | |||
| min. soldermask dam | 100µm / 4 mil | |||
| suggested soldermask expansion | 50 µm / 2 mil |
Castellated Edges
Castellated edges are not supported with HASL surface finish, please order your design as 2 Layer 1.6mm ENIG board if you use them.
Additional Notes
- Buried, blind, micro or tented vias are not supported
- User-defined subpanels are not allowed, see also here
- Pressfit components are currently not supported.
- Countersunk and counterbore are not supported.
