4 Layer 0.8mm ENIG Design Rules
4 Layer 0.8mm Design Rules
Last Updated: 07/07/2025
Design Rule Files
Do you want to start right away? We provide design rule files for Eagle, KiCad and DipTrace on Github .
The rules listed here shall always be used as reference.
PCB Dimension
min. dimension >10 mm / >0.4 in
max. size 500 x 500 mm / 19.68 in x 19.68
Surface Finish
We use Electroless Nickel Immersion Gold (ENIG) this surface finish offers good surface planarity and high oxidation resistance.
surface finish ENIG
Nickel thickness
Gold thickness
4.0 µm -7.0 µm
0.05 µm -0.1 µm
Minimum Copper Features
Description Capability
min. tracewidth 125 µm / 5 mil
min. SMD pad size 200 µm / 8 mil
min. spacing copper / copper 125 µm / 5 mil
min. spacing NPTH / copper 250 μm / 10 mil
min. spacing NPTH slot <1.8 mm / copper 300 μm / 12 mil
min. spacing NPTH slot >= 1.8 mm / copper 300 μm / 12 mil
min. copper to edge clearance 300 μm / 12 mil
Plated Through Hole (PTH)
All drills with a diameter larger than 0.45 mm are categorized as plated through hole for component mounting, we will enlarge the drill diameter to compensate for the copper plating thickness to ensure that components can be mounted more easily.
min. PTH drill size 0.5 mm / 0.02 in
max. PTH drill size 5.6 mm / 0.22 in
min. PTH annular ring 300 μm / 12 mil
Vias
All drills with a diameter up to 0.45 mm are categorized as via drill and will not be subjected to any adjustments by us.
min. via drill 0.25 mm / 10 mil
max. via drill 0.45 mm / 18 mil
min. via annular ring 100 μm / 4 mil
Minimum Drill Spacing
min. drill spacing 300 μm / 12 mil
NPTH Slots
NPTHs Slots that are smaller than 1.8 mm are nibbled. This is a time-intensive process, so we reserve the right to limit the use of nibble slots in a design. Diameters above 1.8 mm will be milled and are thus preferred.
preferred NPTH slot diameter >= 1.8 mm / 0.07 in
min. NPTH slot diameter 0.8 mm / 0.032 in
max. NPTH slot diameter :infinity: No restriction
PTH Slots
min. PTH slot diameter 0.7 mm / 0.028 in
max. PTH slot diameter 2.6 mm / 0.11 in
min. PTH slot annular ring 200 µm / 12 mil
Silkscreen
We use Peters SD2692 ink for the silkscreen on our PCBs and apply it using the direct printing method. The smallest supported width is 150 µm / 6 mil, all silkscreen features with a width less of that will be adjusted. Silkscreen printed on pads is not supported, we use openings in the soldermask as reference to cut away / remove the silkscreen in the affected area. Do not use the silkscreen to produce large fillings, designs which cover more than 25% per PCB side will be rejected.
min. silkscreen text height 800µm / 32 mil
min. spacing silkscreen / pad 125 µm / 5 mil
silkscreen on pad not supported
max. Silkscreen 25% of Board size
Soldermask
We use high-quality Peters Elpemer AS 2467 SM-DG green soldermask which is well suited for the ENIG finish. Please refer to our soldermask specification for the electrical properties of the soldermask.
soldermask dam between pads recommended but not required
min. soldermask dam 100µm / 4 mil
suggested soldermask expansion 50 µm / 2 mil
Castellated Edges
We manufacture castellated edges free of charge, please refer to our documentation on how you can set them up.
Stackup
We use Panasonic Prepreg 1080 Type R-1551(W) (58.9 KB), Peters coatings and Elga Copper foil.
Our Boards are RoHS and REACH compliant.
The following track layouts can be used to realize defined impedance. Please note that these values only provide a basic orientation. Interference factors such as angles, meanders or vias in the routing of the tracks may negatively affect the intended impedance.
Defined Impedance
These values have been taken from the 1.6mm 4 Layer Pool are have not been verified yet.
Type Impedance Signal- / Reference Layer width space width
Single Ended 50 Ω TOP / IN1, BOT / IN2 245 µm - -
Differential pairs 90 Ω TOP / IN1, BOT / IN2 230 µm 165 µm 230 µm
Differential pairs 100 Ω TOP / IN1, BOT / IN2 190 µm 180 µm 190 µm
Additional Notes
  • Buried, blind, micro or tented vias are not supported
